-   -   how much hp to 9" houseing? (https://www.racingjunk.com/forums/showthread.php?t=20409)
deepockets 03-31-2008 03:13 PM
with a narrowed 9" houseing and rear brace, and 4 link. when is it nessary to go to a chromoly after market houseing. to what hp will it be safe to?
bjuice 03-31-2008 05:20 PM
assuming you have
good axles 35 to 40 spline ( have seen 33 spline live)
a good aftermarket 3rd member with billet caps ( pull thru bolts)
set the car up with the 4 link with minimum body roll
also depending on how much you narrowed the housing..this promotes strength in itself
i have seen them run well over 1,000 hp..hooking with 1.12-1.13 60 ft's
