ruff running sbf
anyone got a suggestion. we started up 306ci ford last night. motor was pulled out of car and heads and intake removed and new windsor jr.
intake reinstalled all new gaskets, new oil pump, new plugs, freshlt rebuilt holley 750, new msd 6al, new msd distibutor, new coil, and now it sounds like #2 cylinder is dead. the heads are trik flow twisted wedge, and this motor ran great before we pulled it. it only had a small rear main leak that is why we pulled it. We changed wires,coil,and msd box and still missing. #2 header is not hot but we checked for spark and plug lit up like christmas light. Any Ideas? quickboss |
SBF
The first thing I would do would be a compression check. I would go from there. Is it possible the valves to #2 are not adjusted properly?
Are you sure your firing order is correct? Some performance cams use the 351W firing order. 302 is different in stock form...
If the compression is good, and the valves are adjusted right, and the firing order is correct, I would guess you have somthing in your intake or head. are all your red rags present and accounted for? Take it from s
someone who knows, an engine wont run right if a red rag gets down in it! Heres another one on me, I keep 8 racket balls in the velocity stacks on my hilborn setup, I was in a hurry to get loaded one morning and jumped in the car to start it up and load it. It wouldn*t fire a lick, and it sucked those racket balls all the way to the butterflys! |
For sure check the firing order. Happened to me in my service van, got a re-man 302 and swapped everthing over and started it up and it ran like crap. spent hours trying to figure it out. good spark but dead holes. Finally figured out that it was a HO 302 that uses the 351 firing order. Felt stupid but hey I'm a chevy man.
CHECK THE FIRING ORDER!!!!!!!!!!!!!! :oops: :oops: :oops:
LIVELY |
:shock: :shock: I think it's the firing order :? :? and i am a mopar man :!: :!:
If it's just cyl 2 that's dead I doubt it's a firing order problem, you would have 2 dead cylinders because you can't cross just 1 wire. As far as the different firing orders on the Fords go cyl 2 stays the same. The common firing order is 1 5 4 2 6 3 7 8 the windsor and ho 302 is 1 3 7 2 6 5 4 8. If you are using a pcv valve on it I would look at where you plumbed it in. A common mistake when changing the intake/carb is to hook it to a vacuum port that comes off of an intake runner. This will lean out 1 or 2 cylinders that are fed by that runner.
| All times are GMT -8. The time now is 02:10 AM. |
