-   -   engine bearings SBC (https://www.racingjunk.com/forums/showthread.php?t=20446)
dgordner 04-04-2008 02:30 PM
engine bearings SBC
Would someone tell me the difference between the Clevite MS909P Main bearing and the MB2508P Main Bearing.
jmarksdragster 04-04-2008 03:06 PM
The MS909P is a standard LJ350 main bearing. The MB2508 appears to have a .020 reduced width on the rear main, probably for a block that spun a rear main and required repair.
dgordner 04-04-2008 03:23 PM
Thank you very much. I quess it would be smart to replace it with what I took out correct?
Tod74 04-04-2008 03:32 PM
I would...unless of coarse what you took out wasn't working. :D
jmarksdragster 04-04-2008 04:10 PM
This site gives you measurements for that bearing. Measure your block and old bearing.
http://www.enginetechcatalog.com/Int...Set%20-%20Main
dgordner 04-04-2008 05:22 PM
Thank You !![/b]
