racepump or belt drive??????
Can anyone give me a good reason not to run a "racepump" on my drag car? I'm converting to alcohol this year. I already have the carb (rupert's 1150). I still need to convert the rest of my fuel system. The "racepump" seems like a neat little setup, but I don't know anyone running one. I have a 3000lb door car 477ci BBC, 1.32 60', 7900rpm trap, 9.40's in good air on gasoline. Should I go to a front mounted fuel cell? Any input would be appreciated. I just want a good consistent system. I don't want to spend uneccessary money, but I understand you usually get what you pay for. Also any thoughts on keeping the crankcase evacuated?
Re: racepump or belt drive??????
hammertime, WHO MAKES A GOOD BELT DRIVE PUMP?
APD www.apdracing.com Ron's www.killerrons.com & BLP I am sure they have a website just not sure what. I've ran all 3 of these and had great luck with all 3, Just make sure when you do this you get a good bypass regulator, I am sure APD and BLP both |
If you plan for alcohol go with the beltdrive.
http://www.blp.com/ |
pump
In the late 80s, I had a 468 in a firebird that ran 9.0s with a tunnel ram. I ran the Clay Smith Engineering manuel pump. I think it was rated at 130 gph, gas or alky. I was told it was not enough, Bought the whole Barry Grant 400 deal, and guess what, still 9.0s :shock:
Belt or cam drive pump all the way.
Enderle Hilborn Waterman CSR and the companies mentioned above. All good products. |
| All times are GMT -8. The time now is 06:39 AM. |
