350 build question
Building a 70's sbc and adding a set of 906 vortec heads, stock style roller rockers (1.5) with a low lift hydraulic cam (under .500). What should I use for a push rod the stanard lenght (7.793) ?
Thanks Hardcase |
pushrod
You should be able to use the stock length pushrod but you still need to check to be sure.
| All times are GMT -8. The time now is 02:05 AM. |
