-   -   timing (https://www.racingjunk.com/forums/showthread.php?t=20488)
bakerboys 04-09-2008 10:14 AM
timing
whats the best gear drive or timing chain bbc 512 13.0 to 13.5 compression
hammertime 04-09-2008 10:28 AM
Re: timing
Timing Chain Cloyes Hex-Adjust
zipper06 04-09-2008 01:58 PM
Re: timing
X2 Cloyes, or if you can afford it Donovan gear drive.
Tod74 04-09-2008 02:16 PM
I like the one made by Cloyes that has the slotted holes that you can turn the cam gear like a jessel. Alittle expensive for a chain but much easier than fooling with those bushings.
sg1586 04-09-2008 02:42 PM
Jesel............... :D :D
bjuice 04-09-2008 05:27 PM
i prefer gear drives over chains,due to the the claims that are made of gear drives....google gear drive and read about them..
if your gonna go with a chain..get a cloyes TRUE ROLLER chain..
i agree with Zip on the brand of gear drive..i also run one in my 511ci and jessel belt drive on my 632ci
zipper06 04-09-2008 11:42 PM
Actually i have no experience with B/blk in the last 20 yrs. except for the one i built last month. On my s/blks i have a comp/cam belt on my 434" that's going in my car shortly, but i have a Jessel under the bench as a spare that i bought dirt cheap on the other 2 engines i have hex adjust cloyes. When i ran a blown alcohol b/blk in the 80's i used a donovan gear drive and that's what i was basing my answer on. The b/blk i recently built i used a cloyes hex-a adjust chain, cost $140.00.
You can for sure spend more, and not get better.
