-   -   first big block (https://www.racingjunk.com/forums/showthread.php?t=20492)
ncoffroader 04-09-2008 04:23 PM
first big block
:oops: i just bought my first bbc(454) and have no clue what is what,square/round port is this intake or exhaust?are big and small block dist. the same?tranny bolt pattern same?any help would be greatful thans
lanham 04-09-2008 04:33 PM
big block
Transmission bolt pattern is the same as a sbc.Distributor is the same.Rectangle port and oval port refers to the intake runners.
ncoffroader 04-09-2008 04:37 PM
thanx
thanx now time to buy some parts
cepx111 04-10-2008 12:03 AM
Welcome to the land of woo..
Goodluck, Charles
Tod74 04-10-2008 05:29 AM
Welcome to the land of goofy valve train :lol:
ncoffroader 04-10-2008 07:45 AM
engine identification
ok now i have some basics can somebody tell me what i have and is it worth going thru? on back of block it has the number 364779 cast into it,thanx ahead of time for the help
superstreet2055 04-10-2008 07:56 AM
Codes
all of the casting number codes you're looking for can be found at www.mortec.com.
ncoffroader 04-10-2008 08:08 AM
casting number
i looked up the casting number and it says its a "366T" so that means i have a bbc with small block displacement?what a piece of crap! :x so what do i do junk and start over or is it worth fixing?
sc3314 04-10-2008 08:28 AM
Block
all depends on what you are looking to do with it? What you have is a standard truck motor.
ncoffroader 04-10-2008 08:33 AM
my plans were to put it in my suburban,i am running 46" tires so i was looking for alot of torque
