-   -   powerglide rolling forward when applying transbrake (https://www.racingjunk.com/forums/showthread.php?t=20521)
schultzeracing 04-13-2008 08:09 AM
I just went to the track this past weekend, the transmission had no passes on it at all and when i applied the transbrake it rolled forward. The band adjustment is fine and the line pressure is good. Does anyone have any idea what could be causing it. I know i can run the line lock with the transbrake but i would like to stay away from doing that. thanks alot, nate
hammertime 04-13-2008 08:44 AM
Several things can cause it, you say the band is correct where is it set ?
jmarksdragster 04-13-2008 08:44 AM
What is your line pressure? Should be around 200 psi. Band servo should be a dual ring for best operation. Pressure leak somewhere will cause it, solenoid valve not aligned properly. What type VB, pro tree, standard or double dump?
schultzeracing 04-13-2008 09:21 AM
The band adjustment is 3 1/2 turns out. pressure is around 220, i have a tci dual ring servo, with a tci pro tree brake. Thanks for the replies, nate
jmarksdragster 04-13-2008 09:27 AM
3 1/2 is a tad tight for me but not your issue. Drop the pan and make sure the solenoid pushes the valve in all the way.
hammertime 04-13-2008 10:12 AM
What he said
johnracer 04-13-2008 11:41 AM
If it rolls forward with the brake set, the reverse clutch isn't applying. If it rolls back, it's a band issue. Could be as simple as a brake solenoid failure or wrong plunger, or could be a cut seal on the reverse piston. Does it go into reverse? If reverse works, most likely a bad or wrong solenoid.....
schultzeracing 04-13-2008 04:40 PM
I dropped the pan and the solenoid does push the valve in all the way. Also the car does go into reverse. Would the roll stop from tci be an option that could fix it? thanks for all the advice so far. Nate
johnracer 04-13-2008 05:14 PM
Does the transbrake set after rolling forward a little, or does it not set at all?
sommersracing 04-13-2008 05:51 PM
Just as Johnracer said, What is your reverse clutch pack clearance? What RPM do you stage at? Your band adjustment is fine, Reverse is not applying fast enough.
