-   -   re; hilborn stack injection & methanol (https://www.racingjunk.com/forums/showthread.php?t=20547)
suicidebomb 04-15-2008 07:09 PM
I need help
OneBadGMC 04-15-2008 07:54 PM
http://racecarbook.com/
Buy the Injection Secrets book!!! It's WELL worth the money!!!
What help do you need?
suicidebomb 04-15-2008 09:25 PM
I already have Mr. Szabo's books on fuel injection,
bbchevy 04-16-2008 06:53 AM
Injection?
I would say if it was Fine last season?And,now its Not???Well then you have some Issues with Junk in the Fuel System?Have you COMPLETELY pulled the WHOLE System apart and Cleaned everything?That would be where i would Start?
Then,how about the Pump,what condition is it in?
Lastly,maybe check you Throttle blades for adjustment?
HOPE THIS HELPS?
Later
G 8)
suicidebomb 04-16-2008 07:21 AM
I"m in the process of cleaning every part and piece now.
OneBadGMC 04-16-2008 07:54 AM
Can you help me help you?
I need the pump GPM, nozzle sizes, main bypass pill size, poppet pressures on main & secondary.
Is it a Hilborn or Enderle barrel valve?
suicidebomb 04-16-2008 09:53 AM
It has a hilborn barrel valve
OneBadGMC 04-16-2008 10:12 AM
What's the pump GPM @ 4000 Pump RPM?
Do you have flow at the industry standard 100 PSI?
suicidebomb 04-16-2008 11:05 AM
My engine is running out of gas
OneBadGMC 04-16-2008 12:06 PM
You have a PM.
