E85 set-up questions
So, for those that have converted to E85 that are running injection, What kind of jet/ tune-up changes did you make? Does anyone know were to go to get info on this?
I have a 96 Ed Quay Dragster (1830 lbs.) that currently runs 7.90s @ 170. mph in the quarter (about 700 horsepower est.) on Methonal. My car runs a a Rons Flying Toilet Injection system. This is a constant flow mechanical injection system w/ a Waterman .500 pump that turns 4.85 gal per min. On Methonal I'm running .31 nozzle jets and a .70 main jet with a 6 lbs. relief spring. I am very interested in converting to E85. Is anyone one here currently running a similar set-up? Can anyone give me an idea of were to start ? Can anyone put me in contact with someone that can help me with set-up? What kinds of temps should I expect on an EGT system if I'm running 32 deg. timing? Should I change the timing in my car on E85? What type of water temp. gains should I expect to see during a pass on E85? What type of Air/ Fuel Ratio numbers should I see on my O2 gauge? Is there anything else I should know about E85 before running it? Your help will be greatly appreciated. Thank you in advance. Raymond Keown Precision Performance Racing A2Z Racing NRG Swimming Levittown, Pa. 19056 [email protected] 215-715-4290 |
e85
Just bought a barrel today,will test next week .Hope to drop only main jet a couple of sizes, we run two dragsters /bbc/ Enderles, tell you what a found!
| All times are GMT -8. The time now is 05:05 AM. |
