oil pump spring
Hi guys i did a search but couldn't find anything on this, i am changing my spring in my oil pump to a high pressure one, i noticed that in the pump it only has one hole so makes it kinda tricky to get the pin out, is there any easy way to get this out or a diffrent way instead of cutting it to get it out.
thanks |
take the cover off then you can remove the pin.
oil pump
Just a good idea to weld the pick up onto the pump. When you change the spring. The Moroso billet pump has adjustable pressure settings for $100.00
JMT |
| All times are GMT -8. The time now is 12:10 AM. |
