s10 ses help
i have an 02 s10 4x4 and keep getting a code for the bank 1 sensor 2 o2 sensor. it is 141. i have changed the sensor and it still comes on. i have cleared the code, still comes back. i've changed the thermostat, still comes back. i've changed the ect sensor and still, i keep getting the same code. when i clear the code, i can ride for about a day but it never fails to come back and shine at me that i need to service engine soon! please help
Re: s10 ses help
check out this hot motor for your truck :lol:
http://www.sdparts.com/product/12363...eAssembly.aspx |
s10 ses help
hi gearhead1011 you're right, the code is p0141, and i've changed the downstream sensor (bank 1 sensor2) behind the cat, and there is only one downstream. ive actually changed it twice! the first time i did it i had to change the thermostat and the ect, those codes went away but i'm still getting the sensor heater malfunction. i'm f ing sick of it! gas is to darn hi to be riding around wasting it. anyone PLEASE help
The code p0141 shouldn't have an effect on fuel economy. That code just indicates a problem with the heater circuit for that sensor. You can resistance test the heater circuit in the sensor but considering you have changed twice it's not likely you still have a bad sensor. Sometimes when the sensor fails it shorts the heater to ground and will blow the fuse for it. Then after replacing the sensor there is still no power for the heater and it will continue to set the trouble code. There should be a 20 amp fuse in the underhood fusebox for the rear O2 sensor heater.
| All times are GMT -8. The time now is 01:20 AM. |
