-   -   Chevy V6 Stud Girdle (https://www.racingjunk.com/forums/showthread.php?t=20625)
v6spitfire 04-24-2008 05:38 PM
Is anyone aware of a stud girdle that will fit 23 degree Chevrolet V6 Bowtie heads (90 degree V6, not 60 degree V6). Since the 90 degree V6 is esentially a small block less two cylinders, can a standard small block chevy one be modified or is the valve spacing different?
Thanks
Mike
dcarr511 04-24-2008 07:09 PM
Re: Chevy V6 Stud Girdle
Thanks
Mike
Yes you can cut one short and use it. Valve spacing is the same.
v6spitfire 04-24-2008 10:53 PM
Good to know. Thanks
signsbyesa 04-25-2008 05:06 AM
hey bud, i don't know about stud gridles but these guys had alot
of v6 race parts, i bought the stroker kit for my v6, worked great.
you can just check it out, thought i would thro that your way. :wink:
http://www.engine-parts.com/
