-   -   master lube verses accusump????????? (https://www.racingjunk.com/forums/showthread.php?t=20690)
badbug3 05-01-2008 12:29 PM
whats the opinions of the moroso or canton accusump compared to the master lube stand up style preluber and oil pressure supplier .???
jmarksdragster 05-01-2008 12:59 PM
Both do the same job, I have the Accusump on mine. I got i new on e-bay at a decent price. I will not run without it.
edvancedengines 05-01-2008 04:40 PM
Canton is the original to make use of this technology for racing. All others are a knock -off copy cat and are not quite the same.
Also buy the electric solenoid and wire it up.
Ed
badbug3 05-01-2008 06:07 PM
the master lube sits upright and dont have a piston in it like the others that lay down. I was thinking without the possibility of the piston sometimes getting stuck or hanging up compared to the master lube type which is just an open tank with air at the top and oil in the bottom. What do u think about that one.
