-   -   Rebuilding Koni shocks (https://www.racingjunk.com/forums/showthread.php?t=20727)
Oldewalnut 05-05-2008 03:52 PM
I've heard that they can be rebuilt, Just wondering if there is anyone out there that has done this?
In the process of rebuilding my Chevy II, just trying to see what parts I can salvage. The shocks are the aluminum 3 way adjustables but they are better than 20 years old. They do not leak. The springs are likely shot but that is a minor fix.
If anyone knows if this is possible, I'd appreciate some contact information.
signsbyesa 05-05-2008 04:14 PM
i have not sent any for rebuild, but that is what i was told and
it has been in articals in hot rod mag, sending web site for info :wink:
http://www.koni-na.com/faq.cfm
Oldewalnut 05-06-2008 12:32 PM
Thanks signs. I got a local outfit in Indianapolis that carries Koni shocks. Also, wrote down the warranty return number. I'm going to redo the croosbar for mounting the shocks. I may just look into purchasing another pair of something?
I will look into this option.
bjuice 05-06-2008 04:28 PM
i just had a pair rebuilt and got them back 3 or 4 weeks ago...
call Paul at:
Koni Industries
1961-A International Way
Hebron,Ky 41048
(859) 586-4100
the total cost of my rebuild was $350.00 this included shipping back to me.
the cost will vary depending on what parts are needed to be replaced..i think Paul qouted me $120.00 per shock plus parts..
cost me about $25.00 to send them out there...
depending on what type shock you run or have, you need to weigh out the rebuild cost vs cost for a new set...
if you are not looking for a fancy shock ( single adjustable etc...) you can get them pretty cheap..
but in my case my shocks were about $500.00 (each) to replace so the rebuild was worth the cost.
also they will send you the dyno sheet back with the shocks..
also don't be in a rush..it took 5 weeks for me to get mine back...
hope this helps.
Brian
Oldewalnut 05-08-2008 01:09 AM
Thanks Brian.
I wrote that very phone# down from the website. Honestly, I don't remember what the shocks were. But I paid about 350-400(?) dollars for them in the mid 80's. They are the alumnum body 3 way adjustables.
The factor of the rebuild cost versus a new pair was discussed last nite. Once I crawl under the car and identify them, I'll probably call and see what I'm up against and weigh my options.
I have plenty of time. Lots of work to be accomplished. In all Likelyhood, maybe, this time next year I'll be able to get the old girl out. doubt anytime sooner would be realistic.
"Post edit: They are likely double adjustable shocks, I was mistaken. They are the 8212 series shocks. I pulled them off this afternoon after I got off work. These are rebuildable. At least I now have some information to give to Koni."
call Paul at:
Koni Industries
Hebron,Ky 41048
(859) 586-4100
hope this helps.
Brian
