BBC Front Motor Plate
Looking for a 1 piece BBC Front Motor Plate - However I need one that is approximately 13" in height. All that I have seen are either 11" or 12". I have checked Jegs, Summit, S&W, Alston, etc. Wondering if anyone has ever come across a supplier that sells larger ones.
Thanks – Scott |
maybe the Chassis Shop ??
If not I am sure you can call a local builder and have them make you something. |
Quartermax.com which is Rick Jones company has plates, but they don't give dimensions on their web site.
I had already called Quartermax. I contacted the Chassis Shop today, and they don’t have one either. Thanks for the suggestions.
How about Chassis Engineering or A.R.T.?
Steve |
Motor Plate
Call the Chassis Shop ext.13 Max.Tell Him Exactally what you Need?
If he dont Help you,Tell Him that G is Going to Slap the TASTE out His Mouth! Hope this Helps? Later G 8) |
bbc motor plates
I have new or used 13 in. plates
Update
After checking all around and not having any luck, I checked back with S & W Race Cars, and they custom made a front motor plate for us. |
| All times are GMT -8. The time now is 10:28 PM. |
