35 spline alxe free play question
i was running strange 35 spline spool and axles, and just got from moser a new set of axles with the 5/8 studs. the play is sloppier than the original strange axles. i put a dial indicator on the stud and came up with .032 thousands of play. does any one know what is axceeptable. i just dont want to go by what mosher says.
Sorry but MOSER sucks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! David.(what did moser say is ok?)
you can call strange for tech, their good guys http://www.strangeengineering.net/
or tom's differential, good knowledge http://www.tomsdifferentials.com/ let me know what worked, that does sound like alot of play, never had that problem, good luck :wink: |
moser said up to .080, but i need someone else's opinion be fore i'll run the car
My Moser's are sloppy,too.Never measured it(will now :shock: )but don't think it's that bad.My buddy's Strange's are tight.Can you get too tight?
moser
I agree, moser sucks!!!! I only buy strange axles!!! They are very sloppy and from my history, they are weaker than any other axle i have ever had even stock ford.
From what I understand Mosier parts vs Strange Parts are not interchangable.. Like using Mosier Axles in a strange spool ect.
Have not tried it but that is what I had been told at one time. Have you talked to Strange about this? If it were me I would just to get their opinion. |
when i ordered the axles from moser, they asked who's spool i was useing and i said strange. i did call strange today and they said up to 3/32 of an inch. tats aprx .090
I have Moser axles in a strange spool.
| All times are GMT -8. The time now is 05:17 PM. |
