-   -   Retro-fit Powerstroke???? (https://www.racingjunk.com/forums/showthread.php?t=20917)
olds48 05-25-2008 09:29 AM
I have just recieved a FREE 1993 F350 2wd with a 7.3L Powerstroke and automatic tranny.Tranny "fell out" and guy just wanted it out of the yard.I have been wanting either a 7.3L PS or an old 12 valve Cummins.I have a 1972 C20 that I am swapping over to 4WD and want to put that motor in it.Does anyone know of any adapters to fit this motor to other types of bellhousings.What I have now,and would like to use,is a SM465with a NP205 on it.Anyone know anything about the automatic tranny behind these Powerstrokes?Worth rebuilding??I can divorce mount my 205.I haven't even seen the truck,got set up with this deal thru my Dad,he bought a backhoe from the guy.It might be eat up with electronics,for all I know.Any info on retrofitting these engines into non-computer situations would be great.Thanks alot!!
johnracer 05-25-2008 11:45 AM
I don't think Ford had the Powerstroke until 95-96. They had a 6.9 and a 7.3 diesel alright, and some were turbocharged, but they didn't run anything like a PS. They were just a mechanically injected International diesel....might want to check it out before you drag it home.
Tod74 05-25-2008 08:09 PM
free is free. Even if you don't use it you can part it out.
Cogburn 05-26-2008 07:05 AM
I'm not sure what tranny is behind that 7.3(there are 4 different auto trannies for that truck) but I would just use the ford trans. The older fords used a C6 behind the diesels and it worked ok.
That should be a good swap...I have an old '73 K20 that I have thought about mounting a 4 door cab on and shortening the box to fit with the 4 or 6 cylinder Cummins diesel. The 6.9 or 7.3 ford would be just as good(less mpg though).
olds48 05-26-2008 02:44 PM
It is a 1994.Don't know if a turbo or not.
suicidebomb 05-26-2008 02:56 PM
Olds, my father in law, has had both engines in different trucks, I'm not real sure a guy can kill em, they both have Lord only knows how many miles, and just keep on chuggin.
suicidebomb
olds48 05-26-2008 06:12 PM
Yeah Earl,no doubt they're tough.I like the 7.3s,don't care for the new 6.0s.Mt Dad and exgirlfriend have one,not impressed.I just wander what it would take to make it electronic-free,if possible.Guess we'll find out :D
olds48 05-27-2008 06:27 PM
Just got home with the truck a little while ago.It is a '94.Guy said it was a 7.3.I can't tell by looking at it.The fender says "Turbo Diesel"but doesn't say "Powerstroke".Anybody know the difference,or is there any?Thanks
sc4405 05-27-2008 07:49 PM
Dieselstop.com is all about these engines in all year models. If you can't find the info there, it just doesn't exist. I do think the very early 6.9 engines were NOT turbocharged and had all mechanical controls, so your "turbo" designation may mean you have a 7.3. Check it out. 8) JB
johnracer 05-27-2008 07:53 PM
Like I said before, the Powerstroke didn't come out until 95-96. So unless it's an oddball, it's not a powerstoke. The mechanical injection International 6.9 & 7.3's had the fuel filter on the rh side up high, spin-on and glowplugs that are where spark plugs would be.
The 7.3 Powerstoke is all electronic, has the fuel filter in a cannister in the valley, and the glowplugs and electronic injectors are under the valvecovers.
If you can get me the 8th digit of the VIN, I can identify it for you.
Later,
Johnny
