-   -   Manley Aluminum rod torque (https://www.racingjunk.com/forums/showthread.php?t=20925)
jmech 05-26-2008 12:48 PM
I purchased a 468 with 10 year old Manley aluminum rods. The rods only have 20 passes on them. I'm going through the motor and can't find torque specs for the rods. They have 7/16 ARP 12 point bolts. Can someone help me with torque specs for these rods? Thanks...Jeff.
mudjeep 05-26-2008 12:58 PM
Its best to use bolt stretch on rods, If they are the arp 2000's around 6 to 6.5 thou should work
jmech 05-26-2008 02:19 PM
I don't have a stretch guage. There's no number on the bolts, just stamped ARP.
poncholvr 06-11-2008 06:24 PM
tightening rods down to a ft lb, should be good enough-- rod stretch or not
use plasti gauge to measure the correct gap
even if they are a lil stretched the torq shouldn't be affected, always measure properly,and your ride will keep on running :D
