-   -   oil restrictors dart little m block (https://www.racingjunk.com/forums/showthread.php?t=20927)
altune 05-26-2008 07:23 PM
I am completeing a build on a dart little m setup. The cid is 436 strictly for drag racing. I had orderd a short block from a reputable builder. I am about to install it in the car and a friend remineded me to check for the oil restrictors in the block near the back of the engine, I opened them up and found no restrictors at all, just wondering if they have to be there and if so what size is recomended?
Thanks
Al
jmarksdragster 05-26-2008 08:12 PM
Should be 1/4" pipe threads in front and back, I think I used plugs with .070 in back and .100 in front.
altune 05-27-2008 02:14 PM
Ok, the guy that built the engine told me that , the lifters are a special type that restrict the oil flow to the top end and restrictors are not needed.
the lifters are PBM made my morell.
any ideas??
need to put this thing together today.
Al
promod45 05-27-2008 03:54 PM
dart block
i have the dart rocket block and on there web site it shows you where to put them on the rocket block, check that out..
