Pistons?
I NEED a Set of Pistons?
I Purchased a Basket Case,was suppose to be 1-New Set of Pistons alond with a New set of Rods?Well,the Rods are here,but ONLY 1-PISTON? It is a VENOLIA,so i would like to have a set of Venolia's?But,NOT absolutally ness? Bore 4.460 Comp.Heigth 1.520 Dome .290 to .300 that can very a LITTLE? Pin Dia. 1.094 The Top Ring is down about .360 Top and 2nd Ring .060 Oil .185 Just for SAFTY Sake,i would want to sent the 1-Piston i have to whoever Orders these Pistons?Since i have it?Why Not? THANKS Greg 8) [email protected] 231 690 5075 cell |
i think venolia are more of a custom piston not off the shelf, what the
pro's use. all the shelf piston companys can make custom slugs, so, (my thinking) either match the venolia or order a complete set, i bought the lunati pistons, 4.310, off the shelf, but most companies will make custom, good luck :wink: |
Contact Ed Wilson (Edvanced Engines) he is a wd for BRC Performance. They can make you a custom set as good or better and way quicker than Venolia, and at a very competitive price. Ed is a member here, check out the sticky thread here about his pistons, I am using them in a SBC with over 700 hp of nos.
Ed's phone # is 972-633-0563 |
The 1.094 pin size is what's going to hose you.
That pretty much defines aluminum rods. I just bought a set of pistons from Diamond, ran me about 1300.00 with pins, pin buttons, and rings. Pistons were gas ported, using .043/.043, 3/16 rings. Fully CNC top, 10.4:1 with 121CC head and a .050 head gasket. If it wasnt for the pin diameter, you could probably pick those pistons up off the shelf from J/E. |
Pistons
Thats a Standard Hemi Pin Dia.
We have Always Used a Hemi Pin in our BLOWN Chevys. THANKS G 8) I did Talk to Ed yesterday,if i deside to do this?It will be done will His PISTONS! |
You cant go wrong there, Ed and Brc are unbeatable. I was usung Venolia and keeping them in buisness going through about 6 sets per season, after using Ed's Brc my piston issues are gone.
ross /brc- arias,and wiseco-
wiseco are great pistons |
| All times are GMT -8. The time now is 11:45 AM. |
