-   -   tbi problems (https://www.racingjunk.com/forums/showthread.php?t=20965)
dragracerx 05-30-2008 07:43 PM
tbi problems
i have a 95 gmc jimmy with 350 4x4. i have starting problems after spray startin fluid it runs fine. and will start up with no problem. i have a intake and carb to replace the efi would like to keep it. but it keeps actin up.
johnracer 05-31-2008 06:39 AM
Since it's a Jimmy, I assume you swapped the 350 into it. The original V6 and the 350 are both TBI not CFI correct? Did you change processors too? Sounds like it's not getting enough cold enrichment. Might be a coolant temp sensor problem, or the "crank" circuit may be dead. Should have a fuse in the fuse box labeled "crank"....
