-   -   Starting Issues (https://www.racingjunk.com/forums/showthread.php?t=20973)
hammertime 06-01-2008 08:55 AM
Starting Issues
Yesterday while trying to start my car I broke another starter (#3 this year), it also pretty well wasted the flexplate (#3 also). My question is this why am I getting a big kickback when cranking ?
Its a bbc with a terminator that has a primer on it.
So far I am going to do this what do you think ?
Adding a MSD Starter Saver to retard the timing 10 degrees when cranking, I have 0 retard now. This may help ?
Going to buy a new starter that I've used in the past that works great.
http://www.jegs.com/i/JEGS/555/10001/10002/-1
I have another new flexplate I am going to put on it. A TCI and going to order another spare Jegs Flexplate ($42.00 compaired to $65.00) just in case.
http://www.jegs.com/i/JEGS/555/60151/10002/-1
I've been told to elminate the ford selnoid and run the wire back to the starter instead ?? Any truth to this helping ?
I checked volts on mine going into it 12.2 coming out 10.6 back to starter.
When I am cranking the motor over without ign on I am 12.2 volts everywhere as soon as I crank its 10 volts untill it starts ?
Before anyone jumps to grounds and powers this has all been checked and grounds been added to block, chassis all 2 gauge. Powdercoating has been taking off and also paint on block.
Battery is a newer Optima Red Top and is good to go
My next solution to all this mess is going back to a carb, this is a common issue with injection but hate to give up on it because its a copy machine right now.
Any thoughts would be appreciated.
curtisreed 06-01-2008 01:05 PM
David
Is it doing this when it is cold or randomly? Are you on alcohol or gas? Did you change anything in your combination this year? One question I have is why do you run the Ford Solenoid, I.E. what are you trying to isolate or protect with it?
Curtis
dak697 06-01-2008 01:07 PM
I have done the ford solenoid and it seems to work good.
The only thing I might try different is the battery. Borrow a battery (fully charged) and give it a try. (Steal it out of the pick up)The battery might be the issue.
Good luck
john858 06-01-2008 01:20 PM
if you have your timing locked down the timing retard will solve the problem i would think
hammertime 06-01-2008 04:10 PM
David
Curtis
It does it when its cold more often but still does it when its warm.
I am on alky, I have a primer on it to start with gas though.
The ford solenoid comes with the k&r kit and is wired with it so I used it, lots of buddies use it with there carbs and have no issues. I am going to bypass it this week just to maybe elminate something on the list of could be.
hammertime 06-01-2008 04:11 PM
Good luck
Already took the one off the trailer and tried it, same results. thanks
hammertime 06-01-2008 04:12 PM
My thoughts also I know the 25 degree start retard is way to much though, thats why I am thinking 10 would be good.
sg1586 06-01-2008 04:45 PM
[quote="hammertime"]
My thoughts also I know the 25 degree start retard is way to much though, thats why I am thinking 10 would be good.[/quote
What msd box are you running???? Get a Digital box and your problems will be gone :D
gearhead1011 06-01-2008 07:23 PM
I would go with the 25* retard. My guess is the timing is fixed at about 35* so you will have about 10* in it for starting. If you uses a 10* retard you're still starting with 25* of timing in it.
hammertime 06-01-2008 07:41 PM
[quote="sg1586"]
7al3 box ... digital should of been on it but I was to stubburn and stuck with the al3 maybe over the winter ??
