-   -   Manual Valve body help!!!!!!!!!!! (https://www.racingjunk.com/forums/showthread.php?t=20974)
jrthone 06-01-2008 01:48 PM
When installing a TCI Manual reverse valve body into my powerglide it says to remove govner assembly.What parts do you take out and what parts do you leave in?????
sg1586 06-01-2008 04:37 PM
Remove all that is connected to the governor support and you should be left with this....
http://www.tsr-racing.com/shop/image...PG-28859-L.jpg
tkilby 06-02-2008 05:55 PM
Yes, but if it was an original rear pump type support, you will need to use a blocking plate under the support.
