Powerglide TCI Manual Valve body help?????
When installing a TCI Manual reverse valve body into my powerglide it says to remove govner assembly.What parts do you take out and what parts do you leave in?????
The only parts that will be left past the rear of the case, will be the governor support and the extension housing......
| All times are GMT -8. The time now is 04:36 PM. |
