-   -   Thoughts On eagles Stuff? (https://www.racingjunk.com/forums/showthread.php?t=20998)
bbb555 06-04-2008 02:00 AM
How many of you would use a eagle stroker kit for a big block chevy? Scott out of new york sells the stroker kit for $1,895.00 and was wondering if any of you wouldn't run this kit and why not? I'm going out of town tomorrow so I need to make a choice today. Thanks,Bill
hammertime 06-04-2008 02:29 AM
Re: Thoughts On eagles Stuff?
Get the good rod bolts L-19's and your good to go. Seen them in 1500hp motors. I have a eagle setup in my 582 and yet to have a failure with eagle (knock on wood).
bbb555 06-04-2008 02:36 AM
Thanks for the info.. I was on EAGLES web-site and they sell their own stroker kit for more than SCOTT.S out of new york does?
bbb555 06-04-2008 02:57 AM
Question,did you buy it already balanced or did you get it done?
tcarda 06-04-2008 03:41 AM
I have had two different with motors (a 469 & a 540) with 4340 Eagle rods and crank with no problems. I did the same thing that Hammer suggested to you and upgraded to the L-19 rod bolts.
bbb555 06-04-2008 03:49 AM
Bill
bbb555 06-04-2008 03:57 AM
Another question? What do you think the hp difference would be between a 10.5.1 (540) compared to say a 13.1-14.1(540)?? Money is tight so I only want to do this once! Thanks,Bill
LuckyDawgRacing 06-04-2008 05:48 AM
I'm running an eagle 4.5 x4.6 with esp & L-19s buzzing to 7800 at the stripe. No problems
tcarda 06-04-2008 07:45 AM
What heads, intake and carb are you running?
bbb555 06-04-2008 09:37 AM
Right now Im running eddy ovals 110cc and a victor jr but getting ready to get a set of AFR 345'S.
