-   -   Internal balancer?? (https://www.racingjunk.com/forums/showthread.php?t=21008)
jrthone 06-04-2008 10:57 PM
Internal balancer??
Im after an Internally balanced balancer for my set up and just wondering what you guys have run in the past or recommend. 632 BBC Dart Big M Ohio crank Ohio rods Wiesco 15.5-1 pistons BB3 Xtra ported heads Methanol injection bird catcher on Victor 2-R Tunnel ram.jesel dry belt drive 850 lift roller cam.MSD Crank trigger with 7AL-2 . 1.76 glide with 4500 converter. Thanks
Tod74 06-04-2008 11:00 PM
I run a ATI super dampr on my 540...but have also used fluidampre in the past...nice balancer. Don't get a cheapo in my opinion.
jrthone 06-04-2008 11:43 PM
What about Pioneer. Are they ok?
hammertime 06-05-2008 02:22 AM
All them good parts put a ATI on it !!
cepx111 06-05-2008 03:06 AM
Not trying to hijack this thread or anything but what is the benefit of putting a fluid dampner ( balancer ) on a rotating assembly that's already been internally balanced?
The balancer is just neutral anyway correct?
I thought they were only of benefit on a motor that was externally balanced?
Learn me.
Cp
Tod74 06-05-2008 03:47 AM
Learn me.
Cp
Good question...I had one on an external balance 454 but have the ATI on my internal balanced motor.
ashtrak 06-05-2008 04:01 AM
ATI the only way to go IMO
john858 06-05-2008 04:45 AM
broken record :) ,don't waste your $,buy an ati
john858 06-05-2008 04:48 AM
quik ? is that 176 tran stock? if it is your going to mess some stuff up!
curtisreed 06-05-2008 04:49 AM
Learn me.
Cp
I think your terminology is getting in the way. It is not a balancer it is a vibration dampener. Doesn't matter if it is internal or external balanced engine as far as the job the dampener is doing, it only matters as far as whether or not it has the extra balance weight on it for internal or external. It still does the same job on either. I hope this makes sense.
Curtis
