-   -   Trans. case broke... (https://www.racingjunk.com/forums/showthread.php?t=21039)
prostreet1972 06-08-2008 03:47 PM
I have a 72 chevelle back halved ladder bar setup, 6 point cage. I was running all solid motor and trans mount. My trans case broke towards the back right by the round thing that a bench mount transmission stand screws into on the left side up ove the top and then back to where the vaccum modulater mounts.
it is just a mild 350sbc, TH350 with shift kit, 5.14 gear footbrake car. Runs low 8.2s in the 1/8 and ran 7.72 on 100hp shot of nitrous
I now know that I shouldn't run all 3 solid mounts, I have installed a poly mount now. Just curious what else would have caused this and what else should I check to hopefully not happen again?
I hope to be getting a 10 point cage here soon, maybe even a 12 point.
Any help is greatly appreciated.
Thanks,
Travis
mytmouz 06-08-2008 03:57 PM
Ditching the solid tranny mount will most likely cure it...
jmarksdragster 06-08-2008 06:40 PM
NEVER, EVER run a solid trans mount. Chassis flex will break the trans. Just because a Chevelle is a full frame car does NOT mean it doesn't flex. The 71 Chevelle I used to have was inconsistent until I welded a roll bar to the frame. BIG DIFFERENCE. That gave me a clue as to how much it was flexing. Put at least a bar in the car, cage is better. ASAP. But still no solid trans mount.
Tod74 06-08-2008 09:32 PM
I have a 12 pt cage and a motor plate and I still use a stock rubber trans mount...if something has gota give at some point I'd rather it be the cheap rubber mount.
john858 06-09-2008 09:38 AM
i think they cover everything!good luck
