gear drive?
why can you not run a gear drive with a solid roller cam?
Who says you can't
gear drive
I do and 3 others, We all run the Milodons. :D Its actually only 1 of a few things We can agree on. :shock:
thanks for the replys guys. ive just heard you couldnt but i didnt understand why.
I run a Donovan gear drive with a solid roller. A quality gear drive or belt is the only way to ensure accurate cam timing with long life.
i don't think i would use a belt drive system even if they gave it to me- :shock:
gear drive-- precision all the way 8) |
gear drive-- precision all the way 8) your gear drive will ware a lil but at least it won't tear, or brake ect... |
The gear drives usually are in blown applications. That I know off. The gear drives transfer alot of harmonics through the motor. The chain isnt so bad but the belt drive is FAR better in that area. Easy cam adj. I run a Jesel Belt and nothing else. My boss jeff on his Chevy Hemi has a jesel belt drive and on his 5 blower motors those are all gear drive.
Replace the belt every season!! |
gear drives
O K, just so I understand this. Its O K to have harmonics in a blown engine but not a unblown? Does the cam drive know or care if it has a blower up top. My Buddies 565 broke 2 high dollar chain sets with less than 75 passes both times. Belt drive kept leaking oil. Yes, 2 of the blown cars We know run the Milodons, so that was good enough for Us and no issues. He does put down a lot more passes than me, but I feel more comfortable with the gears. Replacing 4 chains, You can have a reliable gear drive for the same money. Popping a chain aint cheap, either. :?
| All times are GMT -8. The time now is 02:32 AM. |
