-   -   14:1 comp 632ci (https://www.racingjunk.com/forums/showthread.php?t=21066)
FAT622 06-10-2008 09:57 PM
14:1 comp 632ci
What type of fuel are you people using or recomend on 14:1 632ci combo?
How many galons are you burning during a burnout and a pass?
tcarda 06-11-2008 05:40 AM
If you are running race fuel, I was running Sunoco Supreme 112. I don't know about alchohol because I have never used it. My motor was 13.8 and on the dyno I used 114 and 112 and the 112 made 8 more hp.
hammertime 06-11-2008 07:11 AM
Re: 14:1 comp 632ci
We've used 112 and 114 both on bigger CI with 14.8:1 compression and see no difference so we went back to the 112. With gas you usually dont use much, maybe a gallon.
john858 06-11-2008 08:18 AM
i use alcohol & i never go back to gas ,just my personnal preferance.
jrthone 06-14-2008 06:51 PM
Im on alcohol as well. i will use approx 17 litres of meth on a burnout and a 1.4mile run.
jrthone 06-14-2008 06:55 PM
Sorry im fron New Zealand. 16 litres = 4.22 Gallons. haha
jrthone 06-14-2008 06:56 PM
Sorry once again im running a 632 BBC 15-1 with hat injection.
hammertime 06-14-2008 09:34 PM
Your using way to much fuel in a 1/4 pass JMO but 3 gallons max is plenty, you have to be really rich.
jrthone 06-14-2008 09:39 PM
Thats including the drive back to the pits. Is that still to much??
hammertime 06-15-2008 07:12 AM
I'd say so, I drive mine up to the lanes (I park usually last car beyond the 1/4 mile so its a drive) make the pass & drive it back and still dont use over 2 1/2 gallons.
