-   -   how much air pressure (https://www.racingjunk.com/forums/showthread.php?t=21075)
vega34 06-11-2008 04:52 PM
how much air pressure do you guy's run,its a 77 vega wagon,weigh 2600,tire size 29/12/15's,i ran last friday and put 9-1/2 pounds and i thought i spun so did my friend watching,didn't hook good,maybe around 8?,,,thanks steve
GotSomeRust 06-11-2008 06:21 PM
I run 9 1/2 in my 83 cutlass. It plants pretty hard. I don't see myself ever going lower than 9. Are your tires getting warmed up in the box? What kind of compound are you running?
dak697 06-11-2008 07:33 PM
If you can, Video tape the rear tires. Then play it back frame by frame to get the best results. I know from experience that it helps a ton. When we changed tire mfg's If was able to run way more air.
us7race 06-12-2008 02:20 AM
If they are slicks (not DOT's) I think I'd start at 8psi go up 1/2 pound each pass until you get the best 60' But you will need to keep the Launch RPM. I run 9psi most of the time but on a slick track 8.5 works better..
vega34 06-12-2008 02:40 AM
thanks,,there hoosiers do6 slicks,,,steve
john858 06-12-2008 06:54 AM
you guys might think i'm crazy buy i run 10.3/4's in my 1432's , i talked to some tire guys & was told to run as much as possible.if the tire balls up when you leave you don't have enough air.add air until it doesn't ball up & then add 1/2lb until you lose 60' then back it down a 1/2lb.jmo.good luck
vega34 06-12-2008 09:52 AM
a guy took a picture of my tire when i left the line,my tire did not wringle at all,thats the reason i thought i had to much air in the tire,i dunno,,,steve
kw89425 06-12-2008 10:33 AM
i dont see alot of wrinckle in that s 10 standing on its ass
john858 06-12-2008 11:07 AM
then i try the 8lb's go up from there if needed,good luck
vega34 06-20-2008 04:04 AM
i ran 9.5 in the tires and pulled the front about 14" my friend said,so that might be about right,,thanks steve
