-   -   mechanical injection pump priming (https://www.racingjunk.com/forums/showthread.php?t=21076)
lsrholder 06-11-2008 05:24 PM
Have a Hilborn ( PG-150A) belt driven pump on one car, and a Crower (80A-0) belt driven pump system on the other. Would like to know if I could use an electric pump w/bypass (to tank) regulator to prime mechanical pump(s) for self starting.
Would a FI pump be better, psi/flow wise rather than a carb pump? Suggestions on max psi to set regulators.
These are gas setups, -8's but could go to -10's if necessary.
Thanks for any help/ideas.........
Alan
OneBadGMC 06-11-2008 06:01 PM
Ok...
http://www.rbssuperchargers.com/Stor...56&InfoID=3921
First you need that nozzle.
Then, since you said you're running -8...
http://www.rbssuperchargers.com/Stor...45&InfoID=3921
You need that adapter on the pump inlet.
Now, simply take your favorite cheap ass electric pump from Auto Zone and connect the two together with a momentary switch. Put the primer nozzle in the distribution block.
Hit the button a few times to prime the entire system and fire it up!
lsrholder 06-11-2008 06:21 PM
Mechanical injection pump priming
:D Hot day'em!!! Easier than fallin' off'a log!
When you gotta know, this is the place to go.......
Thanks a million Alan
OneBadGMC 06-11-2008 07:22 PM
Glad I could help. Just remember that the primer nozzle is -4 line, and the side feed on the pump inlet is -6. So you'll need the appropriate fittings to get it all mated.
RBS should also sell the -6 to -4 fitting for the mechanical pump inlet where you're going to pull fuel from. They'll probably also have the -4 to NPT fittings for the cheapo electric pump. Hoses should be available anywhere.
