weight differece sbc vs. bbc
Trying to figure out what do you guys think the weight difference between a aluminum block 737bbc with splits to a iron eagle block 434 with two carbs. I hope it is around 200 pounds as the motor is way smaller. What do you guys think
A cast iron BBC block is around 270 lbs or so...just the block. A aluminum head is between 37 and 42 lbs and a cast Iron head is about 70 lbs...not sure about an aluminum block and the internals.
I have a bare SBC block and a bare BBC block w/ the center main caps missing in the garage.
The SBC weighs approx. 155 lbs. The BBC Block weighs approx. 200 lbs. I've never weighed a complete version of either but I think a 200 lb. difference is realistic. |
i was always told that there is 150lb differance in a small to big but i'm not sure if thats correct.i hope so cause i'm going big this year. good luck
I swapped from SBC with dart little m to BBC with dart big m. I gained 100lbs exactly. This was actual weight with everything in/on the motors in the car.
cool hopfully thats all mine will be,but my luck it will gain 300lb,NOT THE DRIVER the car :)
| All times are GMT -8. The time now is 06:10 AM. |
