Mark Williams Axles???????
Im buying a new set of 35 spline axles for my Nine inch.Im up around the 1200hp mark in a 632BBC with a 2700Lbs car.Im thinking about Mark williams but also Strange are on the back of my mind. Are Mark Williams hi-torque axles really worth the extra $200usd over the Strange Hy-tuff axles.Let me know what you guys think????????
Nothing compares to Mark Williams. Warning - M/W Splines are different than anyone elses, so you must use MW Spool.
Buy it once. Buy MW. If you already have spool Strange and Moser will interchange. Ed |
I already have a Strange center section ( Alloy Strange 3.250 casing 4.88 Strange pro gears and Strange pro race spool and Strange alloy pinion support). Will Mark williams custom make to suit???
Mark Williams uses 45deg pressure angle on the splines, Strange is 30deg angle. MW will put the spline you need on the axles but you need to specify which.
Thats allright then i told them i was using a Strange spool and gave them a part number. It should be allright hopfully
when you call strange, let them know the horse pwr your running,
their axels can take it, i have notice that there are 2 kinds of rears that the pro-stock run and most run Mark Williams and then the rest use Strange, have not seen moser or anyother style of axels for that much torque. Warren johnnson uses Strange, greg anderson uses MK, i think you'll be ok with strange :wink: |
I have a set of 35 spline MW axles that are twisted big time. Came out of a manual shift 9 second car with a Dana rear. I replaced them with Strange axles.
Strange all the way!!!!!!!!!!!!!!!!!
| All times are GMT -8. The time now is 06:11 PM. |
