coil-over shock?/rear disc brake?
where is the best place,and whats a good coil-over shock for under $200 a pair w/adjustable,,to go on a 77 vega wagon around 2500lbs w/ladder bar setup,
the car has a 8-3/4 dodge 40 spline mosier axle 488 gear rearend,i'm looking to put disc brakes on the rear,so wheres the best place and what type do i need, all help will be appreciated,,thanks steve |
Here are the ones I have..The art Morrison ones page 42 of their catalog to the far right...
http://artmorrison.com/2006cat/2008c...wnload+Catalog These would be better I am sure at more than Double the price though... http://store.summitracing.com/partde...5&autoview=sku |
ok thanks us7race,i went with the ones in the middle of the page(42)
now how about disc brakes on the back,dont want to pay $500 like i seen in the books,,any suggestions,,8-3/4 dodge 40 spline axles,,thanks steve |
hey vega, might check out these guys www.aerospacecmponents.com
under $500. would be stock rotors, you should at least get drilled to help cool the rotors, good luck :wink: |
thanks friend,,steve
| All times are GMT -8. The time now is 10:47 PM. |
