need help picking a cam for a 632
I'm building a 632 and need help. The heads are brodix 18* that RFD is going to do. Curtis said they will flow about 520 intake and 340* exhaust. I'm running a dart tunnel ram with two 1050 dominators. This is a drag radial car that weighs about 3500 with me in it and it has about 13.5:1 comp. I'm not looking to set the world on fire with this thing I'm only looking to make about 1100 hp on motor. Thanks
Re: need help picking a cam for a 632
Probably so, I just wanted to see what everyone else thought.
Cams
Go here and talk to these people;
http://www.bulletcams.com/ They will set you up with one of the best cams money can buy. And they cost no more that any of the other top cam grinders in the market. They will ask for the head specs and flow numbers and grind you a cam to match your engine and requirements. Turn around time is very good also. About 3 weeks. gyrogearloose |
| All times are GMT -8. The time now is 03:11 AM. |
