-   -   Need to ID Mustang II Brakes and hubs (https://www.racingjunk.com/forums/showthread.php?t=21142)
onefaster 06-19-2008 06:53 AM
I have a Mustang II front end. It has what appears to be Ranger wheels and brakes (5 bolt).
The calipers are missing. There is little clearance between the rim and disc for a caliper. This may be why the calipers where omitted, there may not have been room.
1 Where some Mustang IIs made with 5 bolt hubs?
2 What brake diameters and offsets were available?
3 How do I order the right stuff?
gearhead1011 06-19-2008 06:52 PM
There was never a mustang II with factory 5 lug wheels. The pinto front end was the same and they were all 4 lug too. A popular swap was to use ranger rotors but you had to machine the diameter down to make them work. You can buy aftermarket 5 lug rotors for that front end that will bolt right on. You can get them in both ford and chevy 5 lug patterns. check with street rod parts supplier.
onefaster 06-21-2008 03:14 PM
Thanks Gearhead! I am hoping to use some factory calipers to avoid expensive aftermarket parts.
Actually I was hoping to machine the outer diameter on the discs I have to fit some factory calipers. I have a mill, lathe, etc.
I will add some measurements for the people that may come to this post for brake info.
I measured some factory Mustang II rotors. They are 9 5/16" outer diameter, and about .9" thick. The offset is approx. 1.5". the O.D. of the "hat" is about 5.79".
I am aware that I may have Granada rotors.
For conversions using 11 inch Granada discs, with GM calipers, I believe people use pads with a small spacer welded on the back. The GM calipers use an adaptor that costs $110 from Heidts.
Mustang II Disc Brake Conversion Kit From Heidts
These kits use the 11” rotors with a variety of caliper combinations. Kits are available as a bracket kit only or as a complete kit including calipers and rotors.
* GM kit uses ‘73-’76 Chevelle Rotors (4 3/4” BC) & ‘78-’84 Chevelle Calipers.
* Ford kit uses ‘75-’80 Ford Granada Rotors (4 1/2” BC) & ‘78-’84 Chevelle Calipers.
* Billet Caliper Brake Kit uses Wilwood Polished Billet Four Piston Calipers
If any of you have Grenada or Ranger disc conversions, I would appreciate the disc measurements so I can figure out what rotor to use.
I am assuming a Granada caliper is not a bolt-on to a Mustang II. Am I right?
