cracked fiberglass body panels
What would I need to repair a fiberglass body panel that is cracked a the way through? Should I put cloth on both sides? Also, I want to adhere a 'glass cowl onto a 'glass hood? Any special adhesive I should use? First timer, but it dont have to be perfect, its for a mud truck.
coth & risin from the back,drill a hole at each end of the crack(to stop the crack before you do the back),grind the crack & make a small valley then just wipe it with mud. the make some strong two part epoxy to glue the scoop on with you sould be able to get at an autobody supply store.good luck and just take your time. john
john is right on target. but i use kitty hair out front sand then putty. both ways will come out good. good luck
i use kitty hair to just forgot to mention sorry :oops:
I know where there are some kittens I can shave for you if you need "kitty hair". :D
thanks man , all the kittys around here are bald
they should name that stuff kitty hair ball!!! :lol:
| All times are GMT -8. The time now is 02:10 PM. |
