-   -   motor pops through the exhaust (https://www.racingjunk.com/forums/showthread.php?t=21237)
alleyk 06-29-2008 02:43 PM
trying to time my motor ,but it kee4ps popping through the exhaust.
big block ford 460,any help would be appreciated
topcat572 06-29-2008 06:31 PM
timing
If You think the timing is close, 1st thing I would do is compression check it to see if anything is funny in the valve train. 8)
alleyk 06-30-2008 03:18 AM
i got 220lbs of cylinder pressure
I972Nova 06-30-2008 05:56 AM
220 lbs on all 8 cyl??? I would pop the valve covers off and see if any rockers are loose to indicate a prob with cam or lifters.
My 468 chevy was popping through the exhaust, I took the valve cover off and found about a quarter of an inch valve lash. This was the result of a broken lifter that wiped the cam lobe...
alleyk 07-02-2008 01:48 PM
hey josh everything was fine in the valve train, it wound up being my cap & rotor. thanks for your input.
