| CHEVYMATT |
07-07-2008 01:49 PM |
1150 dominator no power valve?
i bought a 1150 hp dominator from a swap and it looks in good condition. i dont recall the numbers but it did come up as a 1150hp
anyway i removed the bowls to check power valves and jetting and found front 84 with no power valve hole at all and rear 86 with no power valve hole at all. it is not even an option .. is this common on the 1150 hp's.or do i have two rear mettering blocks on this carb it also has progressive linkage..
thank you
