-   -   454 Chev racing starter troubles (https://www.racingjunk.com/forums/showthread.php?t=21321)
khib442 07-09-2008 06:50 AM
Motor was completly gone thru, the flex plate is the only thing different.
I have checked everything and it all looks good, but when I hook up the starter the starter gear will hang up. I unhooked the flex plate from the torque converter to see if it was pulling the plate in, but everything is fine.
All bolts are tight and torgued to specs.
I have tried shimming the starter, checking the clearence and it all looks good until you turn the motor over, then it hangs up.
Anyone ever have this happen?
jmarksdragster 07-09-2008 06:55 AM
Cheap flexplate, out of round. JW Wheel is a little more but worth it.[/u]
Tod74 07-09-2008 07:57 AM
Is the starter junk? Can you pull the starter drive fwd by hand and get it to mesh smoothly with the flexplate?
hammertime 07-09-2008 08:36 AM
Re: 454 Chev racing starter troubles
I've had this happen to myself and others, try to shim one side of the starter only. Flywheel isnt on backwards is it ? Just tossing a few things out there
badbug3 07-09-2008 11:45 AM
no prolem
what exactly do you mean by hanging up. Do you mean that when u bump the starter, the starter drive stays engaged in the flywheel? If , that is the problem, then its not a problem. It will disengage after it cranks. If that is not the problem, then explain exactly what u mean by hanging up? Or call me and i will tell u how to fix it. 318-687-9088 gary
CHEVYMATT 07-09-2008 08:01 PM
i had similar situation when i jumped the solonoid from the positive post off the starter and installed a ford type solonoid on the firewall that way i had zero power wires at starter when running . i had to eliminate the juper at starter and two seperate solonoids. good luck jmt
promodjohn 08-04-2008 06:42 PM
Check tooth count on the flex plate with the old one you may have the wrong plate,and its not compatible with the starter.
olds48 08-05-2008 03:11 PM
Is the battery fully charged?I know that sounds stupid,but a low battery can engage the starter,but not throw it far enough in so that it will jump out by it self.Just a thought.
Scooterz 08-05-2008 07:53 PM
Is this a high torque mini-starter? I had to adjust mine as it is a rotating base to fit multiple blocks... once I did this, I had to shim it a few times... because it would pound the teeth on the flywheel.
