Need X-link for Cameron Dragster
I have a 235" Cameron 4-link dragster, and I want to replace the wishbone with an x-link. My lower bars are 17" long, and the mounting holes on the chassis and rear-end are 16.5" wide (center to center). Does anyone have one of these? Any advice is appreciated....
Thanks Spanky |
Re: Need X-link for Cameron Dragster
Thanks Spanky www.diamondracecars.com give Dan a call |
Any advantage/disadvantage to a x-link as apposed to a conventional 4-link? My 63 Vette roadster has the x-link. Is it the same as a swing arm?
Later, Johnny |
Here's the X-link from Vanishing point.... They have made one of them for a friend of mine....
Later, Johnny |
Thanks David. Mine has no body roll at all, but I'm still having trouble getting it to 60' where it should....I could REALLY use some advice/help from someone who knows his stuff. Any suggestions?
Later, Johnny |
Are we setting ourselfs up to go the moon with all these changes, i personally can't see more than a couple hundreds with a change from a wishbone to an X-LINK, body roll who cares as long as the car hooks and goes straight when you're bracking racing. As far as i know there's no index, except in NHRA classes, and as long as the car is consistint, it's then up to the driver to win. I don't know what's good or bad but we run alnite long with a hard tail 235", small blk.on alchol injection 4.80's.
I guess if you have unlimited funds you should try everything just to say you done that been there, but that's not what wins in brk. racing. JMO Zip. |
Later, Johnny When you say having trouble getting the 60's where it should be, you mean its just slow to the 60 ? Give me some more info on your setup and #'s then we can go from there. |
Yes, it's just slow to the 60. I really shouldn't bitch because it's pretty consistent, I just know it'd be a lot quicker if it would 60 like most cars this fast.
The car is a 63 Vette roadster, 107" wheelbase, 839hp RM 522, glide w/1.80 low, 5800 stall, 4.29 gear, 33x16 D1 Goodyears, x-link w/antiroll bar, strut front, 2170#'s full of fuel & me. Current IC is 51.5" at 4.3" high. Best et to date was this spring in Tucson and haven't been to lower altitude since. Ran 8.44 @ 160.19 with a 1.202 60'. Corrected altitude was 3666'. Here in Colorado, the best et is 8.607 @ 157.89 with a 1.22 60' @ 6238'. It rarely 60's that quick. Usually it's in the 1.25-1.27 range w/1.27 being normal running mid 8.70's and low 80's @ 154 or so. This past weekend at 8100', ran low 90's at 152 w/1.27 60's all day. We had a 15-20mph quartering headwind all day too so I wasn't surprized by the et. I've run tire pressures as low a 4 and as high as 6 and adjusted the suspension quite a bit with little effect. It really doesn't seem to respond to adjustments as it should. Of course it's possible I just expect too much, or I don't know what I'm doing. Let me know what you think. Thanks, Johnny |
I guess if you have unlimited funds you should try everything just to say you done that been there, but that's not what wins in brk. racing. JMO Zip. So again i appolagizes for posting on a subject that i'm not qualified to even speak on. Zip. |
| All times are GMT -8. The time now is 05:02 PM. |
