-   -   Powerglide Question (https://www.racingjunk.com/forums/showthread.php?t=21371)
GotSomeRust 07-15-2008 03:44 PM
Powerglide Question
Sorry, still learning. Can someone tell me what this plug is & what it's used for on my powerglide tranny? Thanks http://i282.photobucket.com/albums/k...st/PGPlug2.jpg
mytmouz 07-15-2008 04:00 PM
Speedometer cable...
lookingaround 07-15-2008 04:00 PM
thats where the speedometer cable goes
GotSomeRust 07-15-2008 04:16 PM
Ok, it's a little loose and leaking a little fluid. I didn't want to tighten it if it was going to cause problems.
us7race 07-16-2008 04:09 AM
I always put a freeze plug in it... 8)
jmarksdragster 07-16-2008 05:57 AM
You can pull it out and put an o-ring on it. Also a small seal inside to seal the gear.
GotSomeRust 07-16-2008 08:59 AM
Probably a dumb question, but why would it start leaking all of sudden? I probably put 60 passes on it with no problem.
tkilby 07-16-2008 04:36 PM
I agree, remove all the speedo "stuff", install I think it's a 3/4 freeze plug in and call it done.
jrthone 07-19-2008 09:43 PM
If drag car. As above. Remove and install a frost plug. If not, Auto meter make a good speedo sending unit for the glide
