carb help
Can anybody tell me what would cause my car to die when I go thru the traps and let off the gas. It pulls fine all the way thru the 1/8 and as soon as I let off she dies. It is Dominator. It will start right back up. Thanks Mike
I guess no one else has ever ran into this problem! Thanks Mike
Float level not set correct ? Where is it set
Thanks David, The float level is set at the bottom of the sight glass! Thanks Mike
Give it another 100 or 200 idle speed and readjust the mixture. I usually turn the mixtures in equally till the speed starts to drop, back out until the idle is back up and go 1/8 turn richer.
Make sure your primary and secondary butterflies are open the same amount if they are not you may be drawing raw fuel through the transfer slots causing the engine to die.
What sizes are your air bleeds, idle, intermediate, and high. Make sure the high side doesn't have trash in them blocking the circuit.
Give your idle screw's another turn out and raise the float a little higher.
Re: carb help
good luck |
| All times are GMT -8. The time now is 10:47 AM. |
