-   -   GM CRATE ENGINE CAM QUESTION (https://www.racingjunk.com/forums/showthread.php?t=21426)
blkcloud1 07-22-2008 07:39 PM
I'm wondering if you can order a different cam in a gm crate engine? I'm wanting to put it in a pulling truck..if so what cam would you advise? the motor is the 454 HO thanks!
signsbyesa 07-23-2008 05:22 AM
I think you can, i know i was going to order a gm crate v6 and wanted
to change the cam myself and that would void the 3 yr warranty, you
would have to order it from the manufacturer or from the dealer,
scoggins-dickey was highly recommended for crate motors and
they are very helpful, if you order with a bigger cam im sure it
will have the warranty intact, good luck :wink:
