-   -   chassis certification (https://www.racingjunk.com/forums/showthread.php?t=21464)
Xrated1 07-26-2008 10:04 AM
Anyone know the difference between a 7.50 cert and an 8.50 cert?
sg1586 07-26-2008 12:08 PM
Check the rule book
hammertime 07-26-2008 01:20 PM
Re: chassis certification
I could be wrong here but 8.50 is no funny car cage 7.50 is with it
Xrated1 07-26-2008 05:46 PM
Ya, I dont have my rulebook here with me, thought one of the forum guru's could help quick.
zipper06 07-26-2008 08:17 PM
There are for sure 2 things different, as david said funny car cage and the other is the addition of X bars on the chassis under the driver area, i don't know for sure but may have to have X side/door bars also. I have a rule book and it doesn't specially spell this out. I know 7.50 must conforn to SFI 25.2 but not sure what spec. 8.50 unless it's 25.3. Unfortunately you can't get those specs without buying them from the SFI web site. I have a B/P for a tube chassis 7.50 spec car, but not an 8.50 B/P
Xrated1 07-27-2008 09:19 AM
Wow,thats as clear as mud.
lively 07-27-2008 10:10 AM
THAT MY DEAR FRIEND- IS THE NHRA WAY!!!!!
LIVELY
Tod74 07-27-2008 11:05 AM
AND....as soon as you fiund out the specs...and get your car to fit those specs, they will change them. lol
fromcincy 07-27-2008 12:12 PM
There are also a few bar sizes that differ from one spec to the other. Rule book is the answer, and maybe a call to tech inspector
sp2816 07-27-2008 07:53 PM
There is not a SFI 25.3 chassis spec. and there is not a SFI chassis spec for certifying down to 8.50. The following is from the SFI website http://www.sfifoundation.com/
Spec # Full Bodied Cars Price (US$)
25.1E Full Bodied Car Tube Chassis – 7.49 Seconds & Quicker; 2,800 lbs. Maximum 35.00
25.2 Full Bodied Car Tube Chassis – 7.49 Seconds & Quicker; 3,200 lbs. Maximum 35.00
25.4 Full Bodied Car Tube Chassis – 7.50 to 8.49 Seconds; 3,600 lbs. Maximum 35.00
25.5 Full Bodied Car Stock or Modified/OEM Floorpan and Firewall with OEM Frame or Uni-Body Construction – 7.50 to 8.49 Seconds; 3,600 lbs. Maximum 35.00
Spec 25.5 does not need the diagonal braces in the floors if it still has the stock floor pans, where as the others will need them. To be certified down to 8.50, it needs to have the cage per the NHRA rulebook (welded to 6"x6" plates or to the frame, lower outside rocker bars if the floor has been modified more than 2'x2' for transmission removal or no outside frame rails, dash bar if the firewall has been modified, 1 5/8" x 0.118" mild steel or 1 5/8" x 0.083 chrome moly, and bars connecting to the subframe connectors or crossmember if welded to plates on floor. The lists do go on, but to answer your question, I have seen the difference between a 7.50 cert and a 8.50 cert being one bar (not having a kidney bar) or it can be so many more as not having a funny car cage, roof diagonal, floor supports, foot bars, floor diagonals, X-braces, and etc.
Bill Mitchell
