powerglide launch in high gear
I just rebuilt my JW powerglide and had the converter freshened up. Went to the track and had a decent test run on the throttle stop of 9.45 at 152MPH. Great! Now the problem. Went back the pits and decided to bump up the throttle stop RPM. Disconnected the air from the dedenbear stop. Proceeded to put the car in low gear and pressed the transbrake button. started to raise the RPM in this mode with the idea of setting the stop RPM. Got to 3300 RPM and the motor bogged ( like the car shifted into high gear???). Converter stalls at 5600 RPM launch at 5000 RPM Heard a sound like pressure leaking. No fluids leaking that we saw. Checked linkage for tightness - OK Checked pressures at servo - 200psi - OK check band adjustment - OK Still the same problem. Said to hell with changing it and tried to make a pass. the car felt like it launched in low gear after the transbrake switch went off. then took off in high gear and shifted into high. Looking for help/suggestions |
Check the last part of that last sentence ??? " took off in high then shifted into high" ???? !
Here is how the playback tach read.
Revved the motor on the top bulb and launch on the bottom bulb; motor got to only 2800 RPM. stop came on .3 seconds; RPM dropped to 1200 stop came off 2.3 s motor stayed at 1200 slowly built rpm to 6800 and shifted to high hence launched like in high gear then shifted to high gear Just tore down the tranny again and seeing no issues (fliud good, minimal clutch dust no chunks); good seals etc. I think this is a sprag issue on the refreshed ATI converter |
Sounds like a converter problem to me too....
What you explaining has happened to me with TCI.. Had a converter freshened and on the 3 pass the sprag broke!!! With a broken sprag you loose all of you torque ...
A good reason to go spragless, consistency and reliability make it worth while.
its on its way back to ATI. will let you know. Did a "bench check" and it seems ok but who knows under load. what about going spragless for super gas racing? any thoughts. Thanks :) :?
I personally would not go spragless unless you have a big motor in a digger where tire shake on a burn out almost always happens. That alone will brake or damage a sprag. Most sprag damage comes from not knowing how to do a proper burn out properly...
heard back from ATI. He does not believe the converter sprag is an issue. He asked me to check the stator tube to see if it has spun. Tried air through the holes and doesn't look like anything wrong. I'm still looking for the problem. Its nothing obvious. I had him hold off on cutting the converter while I checked but now I think I'll have to sink the $195 they are charging now ( just up from $175) .
ANy other thoughts on what may be going on??? Thanks BTW How I do a burn out.... drive through water box wetting the tires. Don't spin them cause water splashes and may end up dripping on them press the precord button on my playback tach. Make sure the car is in HIGH gear upon getting the signal pump the brake twice and press the line lock the line lock is also linked the burnout rev limiter ( 6000 rpm) I have 5600 stall converter Burnout until hazy and then let the car creep forward feathering the throttle and keeping the RPMat 6000 after moving 10 feet or so drop the rpm and get a nice chirp hit he record button and pull into prestage |
| All times are GMT -8. The time now is 03:17 PM. |
