-   -   spark plugs (https://www.racingjunk.com/forums/showthread.php?t=21481)
contagious 07-28-2008 01:13 PM
spark plugs
Should you use a resistor plug in a drag race motor,or a non resistor plug.is the resistor using voltage or causing a bigger voltage drop than a non resistor plug?
jmarksdragster 07-28-2008 03:08 PM
Non.
