Procharger Motor build up Help
I want to build a Procharger motor, but this is for a 9.90/10.90 Car. .
I would like some input on the motor program. I would like to build a 480-500 BBC 10-1 pistons Alum Heads Alcohol Mechanical Injection 20 psi Boost I know that most of these motors are low compression gas carb or elec fuel injection. Do I build the motor like our Blown SBC Top Dragster deal. Alum Rods, 11.5-1 pistons Or Can I/Should I build it with good steel rods and a good crank What do these guys with 565 BBC and 12-1500 HP have for internals? |
If it were mine it would have at least 11.5 for compression and aluminum rods, but you could probably get by with steel rods at that power level
| All times are GMT -8. The time now is 09:52 AM. |
