-   -   HELP HELP HELP!!! (https://www.racingjunk.com/forums/showthread.php?t=21519)
michigansportsca 08-01-2008 06:48 PM
HELP HELP HELP!!!
1990 corvette, starts, runs, when it gets warmed up stalls sputters quits. And won't stay running.
Scooterz 08-01-2008 08:16 PM
To be honest, if that is the original engine w/ the factory ECU, you are better off checking codes first... there are a mess of sensors on this car. You have eng. code on? This could be any # of faulty sensors to a bad cataletic convertor... needs to be hooked up to the correct software & searched for trouble codes. Good luck!
lively 08-02-2008 01:00 AM
I AGREE --GET IT ON A MACHINE[ WITH SOMEONE WHO CAN USE IT RIGHT] AND FIND IT THAT WAY
LIVELY
6970nova 08-03-2008 02:11 AM
sputtering/stalling
a buddy of mine had the same problem with a late 80s vette it was the injectors good luck
